Blank Screen, RCM okay, OFW does not boot
I always get a bit concerned when i see references such as this as it implies your using retrosix wiki guide… not to be mean to the author (the heart is in the right place) but to put it bluntly the guide is dumb af and promotes dangerous diagnostic techniques (which could cause permanent damage), pointless ones, incorrect terminology (for example " If your VSYS did not pull a short" :upside_down_face: ) poor choice of terms for rails, for example “VSYS” is a terrible term to use for the rail which the BQ IC generates (even though this is how the BQ IC defines it) about another x20 IC’s also use this term for completely unrelated I/O and they are, or can be completely different in voltage (which could lead to disastrous consequences if the user doesn’t know this) - I hope the author stumbles across this post at some point and fixes his guide, it’s shocking quite honestly and has probably destroyed more Switch consoles than it’s saved :open_mouth: anyway,
I’m a bit confused on this, does the Switch boot or no? I’m going to assume I’m misinterpreting the above and assume no and it’s a black screen throughout.
What does this tell you? I ask because there is two rails for the EMMC.
I’m not sure what you mean by this, do you mean you weren’t seeing the console in RCM state (in TegraRCMGUI) until you disconnected the battery and reconnected it? if yes then you have an issue here. I guess you using a Jig to get it into this state or?
Again, need clarification, if it doesn’t boot and has a black screen how are you doing a firmware update? do you mean your generateing newer OS/FW files elsewhere (or you are capable of booting into some homebrew/CFW which can do it?) and then writing them to the EMMC?
Ok, confusion again, this implies it did boot prior and now doesn’t boot, again you need to clarify :slight_smile: (try making it clear as to your definition of “boot” also, ie: boots to Hekate, boots to OS, no boot at all, shows boot logo but doesn’t enter OS, only boots CFW and not stock OS etc etc )
Ok so now this is different to what you just mentioned prior. So it does infact boot both Atmosphere (that’s what you mean right) and stock OS but it’s intermittent, now I understand :slight_smile:
It’s not impossible I suppose. Transfer the data to another module and see if the problem persists :slight_smile:
What you mentioned with the EMMC module is possible. The fuel gauge, Ram, SoC would also candidates which could also cause the symptoms your seeing (intermittent boot)
