I’d verify the size of the diode package with some calipers though first just to be sure.
Provided the specifications are a close match, will be fine as a replacement, though I don’t imagine either of these rails draw anywhere near 1A max, you could probably go lower if you wanted worst case
yeah saw that but down as not recommended anymore and not in stock, the alternative that is recommended is RSX101VAM30 but that is slightly larger than the one I found and the shipping costs are too much compared to the part price and size. Do you thing the ones on RS look ok for the purpose?
Suppose if you wanna do a mouser order and get the order price up for the free shipping then here are some things I’d pick up
a roll of 63/37 Chipquik solder
If your planning on continuing to work on Switch boards, grab some fuel gauages
some more 8316 IC’s just incase
your diodes
That should bring your order up to about the limit if you wanna go the Mouser route
That’s good, likely means the chip hasn’t blown up this time
Can you clarify, do you mean volts? as if you mean mA and you have your meter in the current/amps mode you’d effectively be shorting it out measuring in this fashion
if you mean volts, disconnect batter/power and make sure the negative rail diode isn’t open again, and if it isn’t make sure it’s on the right way round, after this has been verified, check to see if your getting your 1.8V enable present for the -5V rail (there is two of them)
Getting 1.8v on both the 2 leftmost pads to the IC
on the diode i get .14 one way and 1.5 the other which matches my boards that displays but has a ram issue. Assuming as one side is tied to ground from the coil?
pretty sure the diode is on the right way, also checked data sheet before soldering it on to ensure it matches the diode image orientation on the board
Resistance with black on ground = 3kohm / red on ground doesn’t give a proper reading, flashed OL then I just get a moving dot on the screen as if its trying to get the reading but stays like that
Sorry for the delay on this, the datasheet for the IC isn’t clear but it seems to imply the VREF for the neagtive rail is internally generated which would mean provided the -5V output enable is high (1.8V) that 1V should be present at that spot (brown) regardless of what the resistors are doing or what the -5V output is currently at… though I could be wrong, as I say the datasheet isn’t clear on this.
I was under the impression that removing the diode on the -5V rail that one of the many protection modes of the IC would kick in and disable the output for either both or at least the -5V rail and this VREF may still be present, so removed it, but as it turns out thie IC is not quite so robust as I thought and instantly fried it… this explains why your ICs were all dying (because of the open diode all along)
The only case I can think of where my -5V rail was missing was as a result of an intermittent resistor with a bad endcap in that row, I don’t remember but perhaps it was the one connecting to the VREF pin/pad of the IC, I’ll do some more experiments but in the meantime I would check those resistors again and compare to your other board, the other possiblility is that that particular VREF ball is not making proper contact with the board, though I’m not so sure that’s your issue as clearly the IC is at least partially functioning
@Severence no worries, it’s too bloody cold to sit in the shed at night trying to figure this out anyway lol.
I kind of came to the same conclusion as you about VREF as couldn’t see anywhere else it could be coming from although there could be a via under a pad or something.
Does make sense about the diode frying the chips as this one hasn’t gone up in smoke yet so a bit of a good sign so far.
I will try to check the resistors but my multimeter probes are not very fine so do struggle with so many small ones so close to each other. I could try to remove to check but have quite a few of the 0205 ones in the 9th dimension already that it is risky.
The cap doesn’t look good on the side connecting to the IC so may have to replace that. Diagram stakes its 0.1uf, unfortunately my donor is missing the ones above the IC but looking at other posts, it looks as if the ones below the P13 chip are the same so may try to swap one of those out and replace the resistor at the same time for good measure and see what difference it makes.
The datasheet also shows a link between C3 (NON1) and the middle of the 2 resistors coming off VREF but cannot see how that connection is made either. Looks like -5v has a via near the LCD FPC connector but god only knows where that goes. May try tracing it back and make sure I haven’t messed with anything on that side too but as I’m not getting the 1v on VREF, probably not the issue right now.
Appreciate the time you are taking to look into this and try to help me, out of 2 switches I am trying to fix, this one I got with missing components, faulty USB-C and no idea what else is wrong with it and the other one with warped board causing bad ram connections and possibly a bad EMMC it’s certainly not giving me an easy ride for my first go
Bit of an update… I swapped the cap on C2 and reflowed the resistors then got OL on C2 so think you may have been right about it not being on properly but the cap also being shot.
Then took the 8316IC off and tried to reball it damaging the ball area exposing traces. Tried on another 8316 I previously tried with incase it was ok and all the readings on the caps and resistors were within tolerance and no longer OL so I thought great. Before powering it though I checked the caps around the rest of the circuit and the 5v in was shorted so that was a no go, must have been fried with the diode issue but at least I got good readings on the others so hopeful a new IC will solve when they arrive in the week.
8316 arrived, replaced it and it flowed down really well. Checked all the values on the caps and resistors in the area and got good results on everything and no shorts. Got excited and booted it into rcm, injected biskeydump and backlight came on but no display. Got +5v again but -5v was about 300ma.
Not sure where else to look now as readings seem fine, diodes are good, screen is good (tested on another board), getting readings on C2 where it shows OL with no 8316 so pad is soldered.
Could the LCD FCP connector cause this at all? I know you still get +5v and -5V with screen disconnected so didn’t think it would be the FPC but asking as can’t think of anything else at this stage.
Done some measurments, you should be reading approx 160K relative to ground at C2 with or without the IC present.
I’ve duplicated your readings and they only way to do so is by removing the resistor connecting to C1 (pink) or removing the resistor connecting to C2 (brown) which means almost for definite that one of those two resistors is open or they are intermittently open
I would swap these two from your other switch and see if it resolved the problem, don’t worry too much about the capactitor/s as they’re all just bypass caps in this area just focus on those two resistors
Remember to let the board fully cool down before testing results
Not unless one of the pins was bent/bridged and in turn dragging down the +/- 5V rail, I think we’ve already determined they aren’t being pulled low, so this shouldn’t be a concern
My mistake, there is those two diodes side by side on the other side of the board, if one of them was open it would also duplicate your readings, so it might be worth checking them too
@Severence thanks for spending the time to check this in so much detail for me.
The 2 diodes read .261v drop on both one way and ol the other which matches another board.
C2 resistance to ground is 145k, c1 is 11k - could that one be the issue? C1 in diode does give me 1.8v and .735 which matches what it should, would that be the same with a bad resistor?
I can try swapping them out tomorrow and see if it does anything different, worth a try at least
