If the board is unpatched I would run the Biskeydump payload and ensure you get valid BIS keys, the missing cap might be indicative of prior EMMC IC rework
Your reading of 2.5K on your 1V8PDR seems low, but it’s pretty typical for some meters to show wildly different readings here, I would verify this reading against another known goood board
Pointless at this stage, power button and battery should provide those prior rails at a consistent voltage following prompt to boot, if it doesn’t then as I said… battery connector/fuel gauge issue…
I don’t have another board but a tester.
left inductor gives me 800k at the start and gets increased to1400k and right inductor gives me 20k at the start and gets increased to 38k slowly.
I measured the inductors again with my multi tester which is used for the first measurement. and the left inductor mostly shows 3.3k but sometimes the value changed (8k ~ 17k)
However, I’ll wait for the missing capacitor (I ordered) and then continue on this.
