Hi, i have a lite board with the same issue. The only thing missing is the 1.35v output of the main pmic all other rails are present.
Unfortunately I don’t have at the moment a good board to make comparisons but i noticed a short on the upper side of the NFC chip around 2 ohms. Can you please check on your board if you have the same reading? I don’t know if this is normal…
I removed the 2.2k resistor, the two pads are shorted.
