I guess, the switch is now propably dead? Or at least the apu, something crazy happened. I resoldered the chip, even with the little “tip” on the edge, the pulling force of the flux and solder was strong, so I let go. But it seemed a bit odd, I could “sort of” see another column of pads on the mainboard to the left (when the RAM chips are on the right). And in my endless stupidity, although I noticed something was wrong, I put it back inside the case and tryed to power it on. Of course nothing happened, the ampmeter (at 5V, as I dont have something to plug the usb c port in yet) showed miliamp around 0-25 fluctuating all over the place. I disconnected and removed the apu again, just to confirm my prediction: The chip was 1 column off.
How can this happen?
Anyway, I reballed again, this time the first try did the trick, I guess I have more practice now. I then cleaned the board, soldered the apu back on, this time made sure it is in the correct place and plugged the ampmeter in again. Just the mainboard, without any accessories, even the nand is not installed, and I get 20 mA at 5,14 volts, but constantly. I thought it should go to about 15-20 mA but then drop to 0 mA, as it cannot power on or charge the battery.
So the apu is officially gone now? Or should I still put everything back together?
PS: Where can I get an APU for the switch anyway? Do I need to buy a broken mainboard or so?
