This category is for all Xbox One S related questions. Here are a few guidelines for asking your question:
Please be honest (if your cat peed on your Xbox One S then say that!), it makes it much more likely that you’ll get a helpful answer.
My Xbox one s digital version won’t cut on one I was trying to cut and like the white Xbox logo on the game and it just shut off and haven’t cut back on since
My question is about an Microsoft Xbox One S X896144-002 HDD Hard Drive SATA Connector Cable. I’m currently replacing the hard drive in this console and in this sata connector cable it looks like some pins are missing on it. the connector doesn’t look like it is damaged as pins are not shoved back or bent. Long story short I was wondering if thats the way the connector should be or if it needs to be replaced.
