Hello!
I know this question has been asked countless times. I’ve scoured the web, read a bunch of Reddit posts, a bunch of posts on here, watched countless Youtube videos of others diagnosing / repairing their Switch Lites. But, I’m coming up short in my situation, and am hoping that my diagnostic findings will helps someone to pinpoint a better idea of what’s wrong with it!
I purchased the Switch Lite off of eBay, which got delivered a few days ago. So I don’t know the previous situation that got it in this state. It is pretty beat up around the outside, and there is a screw missing from the top. However, after opening it, nothing seemed out of place or disassembled, and the foam was still intact over the exhaust fan. So I don’t think it’s been worked on previously.
A quick rundown of what I’ve tested:
- Tested for shorts around the M92T36 IC. No shorts.
- Tested for shorts around the BQ IC. Also, no shorts.
- Visual inspection of the USB-C port. Looks perfect, with no pins out of place.
- Plugged in a 15V USB-C plug with an ammeter to check. Constant draw of 15V, and ~0.46 amps. This does charge the battery however. And once the battery is full (4.2V), the current draw decreases to ~0.2 amps. Note however, that the ammeter never shows that the Switch actually boots up (ex., it never resets during any boot sequence).
- Removed the board out of the system and unplugged the battery. With JUST the board, plugged in a 15V source and checked with the ammeter. This time, it sits at around 0.02 to 0.03 amps and idles here. As before, no reset to 0 amps and nothing to signify it tries to boot.
- Repeated the same procedure as the previous two, using a USB-A → USB-C cable at a 5V charge. Same exact current (0.46 amps with a battery, 0.02 amps without).
Now, with all that said, here is where it gets a bit interesting. HOPEFULLY this bit will help pinpoint what may be wrong?
If I plug a 15V source in without a battery, the system will draw the 0.02 to 0.03 amps at 15V for about 22 seconds. Then at that time it drops down to 5V instead, and remains at the same current draw.
Furthermore, I came across a comment here by @jkyoho.
(I guess I can’t post links, so it’s in the post titled “Switch Lite Won’t Charge…Help?”)
In it, he lists 3 test points to verify against. The user who made the original post, provided their results:
A → 5.24V
B → 0.04V
C → No Reading
I tested those 3 points on my own, and got the same results. HOWEVER, I noticed something. I got those results ONLY if I plugged in a 15V source, and then waited until it dropped down to 5V. If I tested those points immediately while it was still charging at 15V, I got the following:
A → 15V
B → 15V
C → 4.24V
Even more weird, if I instead plug in a 5V USB power source, I get:
A → 5V
B → 5V
C → 4.24V
So, I have voltage at all 3 of those points, UNLESS I charge at 15V, and wait about 25 seconds for it to drop down to only 5V. When that happens, I lose voltage at B and C test points.
So, it sounds to me like there’s a voltage negotiation problem somewhere. Whether that’s the M92 or BQ chip, or something else, is so far outside my realm of knowledge, I have no idea. I know at this point I can start swapping chips and see what happens. The only problem is I don’t have a hot air station, nor do I have replacement of either chip. I can order them to try, but I was hoping to have a clearer idea of what’s wrong, before blindly buying tools and swapping out chips.
Has anyone else seen that voltage fluctuation like that before? I’m just confused how it seems I have voltage at 15V initially, and I have it at 5V initially, but I lose it if I start at 15V and it drops down to 5V after ~22 seconds. And I have no shorts.
Hopefully I’ve done enough due diligence at this point that it helps to have a better idea of what’s wrong. Thanks for any advice you may have!
