First of all: I know there are very similar posts all over the internet. However, I’m fairly new to diagnosing electronics. I just need some help in my sepcific situation.
I’ve got this nintendo switch. After opening it up, I immediatly noticed some corosion, but not much. I also noticed one shorted capacitor next to the BQ IC. I cleaned everything up with iso, attached the battery and charger and gave it a try. As soon as I pressed the powerbutton smoke came out of the area of the BQ IC and I immediatly disconnected battery + charger.
I then discovered the diagrams of the VSYS Rails with possible shorts by Calvin. My switch has all possible shorts depicted in that diagram. How do I continue? I have no heatcamera or power injection tool, only my multimeter.
I sadly can’t upload any pictures, I guess because I just signed up. The capacitor that I first noticed as being shorted and started this whole dilemma, is the vertical cap right between the IC and the coil.
Well it shows 0 because its…shorted? I think I’m misunderstanding your point. My multimeter beeps on on both ends to ground. When measuring Ohm, it shows something like 0.1 on either end to ground.
0.6 Ohm to ground and 0mV to ground on the shorted one.
On the capacitor above (which should work), I get 481mV and near infinite Ohm (or at least very high).
