Hello,
I’m a beginner at electronics repairing, and I’ve bought a broken Switch lite that won’t turn on or display charging icon when plugged in to train and learn.
I’ve watched a LOT of youtube videos to see how people diagnose problems and tried everything I could to find shorts or broken pins but everything just seems fine.
Anyway, now I want to test if the battery is the problem, so I have 2 questions:
- Should the switch run when plugged through the usb-c port even if it has no battery? I’ve been measuring voltage in the circuit in this case so I was wondering if it was enough.
- Can I use my DC power supply set to 3.8V and plug it in in place of the battery? It feels naive to me to think it’s that simple (for instance, is it okay if I let the temperature pin disconnected?), that’s why I need your help.
Also, I’m having a really hard time finding useful information online apart from youtube and this forum (which is often too specific for my knowledge), is there anything that compile resources about this subject? I’m guessing you always get asked the same things, so I thought maybe someone wrote a summary of usual diagnosis / repairing procedure somewhere but I could not find anything.
Thank you very much!
