I have been slowly working my way around possible issues on a water damaged switch. Having spent a long amount of time cleaning, I am now starting to work through the things that are clearly not right.
There are no shorts in the usual areas, and now that I have replaced the USB port, it slow charges both sides of the cable. When connected to a PC (with emmc disconnected), it is detected, but RCM locks up when trying to inject.
So, the only area that seems suspect is this part by the MAX77812, there is chip on the edge of the chip, and two of the capacitors have almost completely lost their metal on one side. The remaining caps do show a short, but with a bit of a delay, so that may be fine?
So I went through the data sheet and eventually found where it listed the recommended capacitors. And, given that the chip was damaged anyway, I removed it allowing me to see exactly where the traces are going.
This showed me that the output caps seem to be the ones marked green (so are presumably 22µf), and the sys cap I have marked blue (presumably 1µF if I am reading this right).
That left me with the red and yellow caps apparently all going between the same points.
At this point I removed the damaged caps, and luckily one of them had enough metal on the damaged side to get a reading! It turns out that these are 10µf caps.
That does leave the question as to what the smaller yellow ones are, as I can’t see them mentioned anywhere and the larger ones are the full 10µf, but never mind, mystery solved, and hopefully this will help anyone else searching for the info.
I received another water damaged MAX77812 SWITCH LITE BOARD.
Spent sometime on the caps measure. Here is the values for future reference if anyone find it helps
So I have nintendo switch lite with broken MAX77812, replaced chip with new one and now I have blue screen. Compared readings around max chip with working console, and everything is fine except capacitors near phase 3, 0201 and 0603 is 44ohm instead of 0.64kohm. What could be the problem?
