This is a v2 board and I’ve checked all the diode readings on the BQ and m92 area. Most are fine but a few are a little high on the m92 for the normal image floating around with the various readings (not sure if the v2 board is the reason).
The cc2 pads on the port are grounding out. Should I assume the m92 is bad and change it? Thanks for your help.
