Temps after 30 min carging:
Motherbord: ~32C
Nvidia processor: 40C
Inductor: 37C
M92T36: 32C
BQ24193: 35C
Battery conection port: 35C
BCM4356: 33C
All chips on back side: 32C
Ok! it lookes like i’m getting votage on the pins around the m92t36 chip. Which mode on the multimeter would i have to be in and were would i have to poke exactly?
Without battery and charger connected you can check in diode mode (RED probe on ground and with the black probe on the pin/pad) for correct values or shorts. A short on the four big caps over the m92t36 are an indicator that the ic is bad.
The short at pin 39 (LDO28) m92t36 indicates that the ic is bad.
I would remove it, check that the shorts are gone at pin 39 and pin 35 (CC1). If the shorts are gone resolder a new m92t36.
The cap at the bq ic is ok. I measured the same at a working Switch.
