Hi, I have an EDM-020 that I’m trying to fix.
At standby all voltages are present and the startup current also seems to be normal. The issue is that the 5V Start -up voltage doesn’t seem to work.
Near F3502 I keep having 0V. I traced it back to the mosfets not outputting any. The gate of the first mosfet should be tied to 3219A. There’s also no 5V output here. It does get 12V input so that rail is working.
I measured pin 2 of the 3219A which should be signal that i can start outputting if I read the datasheet correctly. This also has no voltage.
I am not sure where to look further for what could cause the 3219A to not work properly. Any input would be greatly appreciated.
Board: EDM-020
Standby current: 0.007
Power-up current: 330-350 mA
Symptoms: Single beeb, no light
