Please be advised, I have used Rich’s Image because my camera is playing up at present and struggling to work out how to convert an Apple photo.
I have an issue with USB-C port. I have replaced it and fairly confident the port is installed satisfactorily, but when I measure one of the pins it is not measuring correctly.
The only part I can see holding this measurement down is the one circled in Red.
I would like to know what this is so that I can pull a datasheet, and also find a replacement…
Unless someone has any other thoughts please
I have currently removed the M92 chip as I was testing for shorts around the chip…all shorts are cleared.
Whilst M92 is off I have taken 2 readings 1V8PDR = 1.9KOhms and 3V3PDR 5.8KOhms
Lastly, in regard to your question, I have taken some new reading around the USB-C port with that small ESD IC removed, and still with M92 off the board
NOTE: original image taken from Geekmatics
@jkyoho that is a very good question. I am sure I read somewhere on this forum about removing the M92 and then taking the readings.
I might have dreamt it though haha
I am going to re-install M92 and then take some further readings later hopefully.
