Hey everyone, I have a xbox one X that has a dead short to ground, I’ve looked over the motherboard and nothing seems to be exploded or burnt, can anyone guide me on what circuit I should follow?
I checked the PSU it is supplying the required voltage.
pigbait - The only way to find a heated component is with voltage injection. The Xbox power supply will have short protection so it will not supply 12v when grounded. Do you have a bench power supply you can use to test?
Usually the mosfets are the first things to go, but the Xbox One X has them glued to the board which makes removing and testing them difficult. You can try isolating components by removing a few capacitors if you feel comfortable doing it and you have a hot air station or hot tweezers.
If you are into fixing things a bench power supply is very important for tasks like this. After a multimeter I feel like a bench PSU is the next thing everyone should get.
