I got Swith lite with no power
When I charge it I see around 15v but power is not working.
So I teardown it and do the short test and I found several short point around MAX77620h and MAX77812 chip
What should I do? Do I need change MAX77620h, MAX77812 or both?
Here is the short point
resistance to ground at these points? probably not shorted
Though the CPU/GPU reg IC below the SoC does look like it’s potentially damaged, can you zoom in on that IC so I can see? might just be the top coating so you might be fine.
jkyoho
August 21, 2024, 3:49pm
6
suspicious, might be just another failed to mod samples
agreed, and also a chunk out the inductor and signs somone has been monkeying around with the CPU/GPU reg. Looks like it’s been through the wars…
I took photo again. I don’t know exactly what is happended it, becasue I bought it used one.
Definitely I can see MAX77812 and around grey component are damaged.
So I have a plan to replace MAX77812 and grey component.
Here is my question what the grey compnent name is qnd how can I buy new one??
And do you think any other problem?
jkyoho
August 22, 2024, 3:31pm
9
I would clean up those test pads and check reading before doing any replacement
I tried clean it. then how can I check it??
ah and I found another point, a resistor is taken out near ram.
jkyoho
August 22, 2024, 4:42pm
11
pads look good, you could measure diode mode reading but not necessary in this case.
The missing resistor is likely a 10k ohm 0201 size, I dont have lite board but v1/v2 has 10k ohm at the F7 pin connected to wifi chip.
I got taken out resistor, because it is taken out when I brused the board.
so I’m gonna try to fix it
to replace MAX77812
to replace the grey component
to solder a missing ressitor
here is my question,
what the component name is? and where is it sold?
jkyoho
August 22, 2024, 10:30pm
13
Grey components called inductor. The value and recommended part number can be found in Max77812 datasheet. You could buy them from SMD components distributors (i.e Mouser/Digikey)
jkyoho
August 22, 2024, 10:35pm
14
Your max77812 seems just the upper skin came off, the marked grey component/inductor looks ok to me. You can check the inductor in continuiyt mode and it should beep from left to right
Really?? Then what should I do?? or How can I find where is the problem on logic board?
Give me some advice please.
jkyoho
August 23, 2024, 6:16pm
16
confirmed with lite came in today.
For troubleshooting board issue, you need to understand what stage the board been stuck/hung on, and what voltage is missing or what current draw from Vsys(battery,
not charge port )
Thank you for your help
I checked thoes
the components beep sound left to right are V
and the components no beep left to right are X
and I checked ohm.
left one is little lower than your number
and middle one of course I can’t checked it
满足以上条件请测试USB-C口以及M92T36 芯片谢谢
I use translator and I will check M92T36.
Thank you.
Acorrding to advice, I’m gonna check M92T36. However I have a question. What is the current value resistance’s ohm around M92T36?
I found several images but it’s all Switch, NOT Switch Lite.
I’m a beginner, so I can’t understand datasheet.
and should I check volts from resistance?
jkyoho
September 5, 2024, 12:35am
21
No, you should check what voltages are present at this point around max77812.
