Is there a way to restoring a hacked Switch back to stock?
Hi Everyone,
I recently bought a dead switch and replaced the LCD connector (broken pins) but the LCD was still black (Backlight worked). I then realized that the Switch was in RCM mode…
Is there a way to make the switch back to stock/normal? I’m not interested to use a hacked Switch that requires a PC to boot it up every time…
I found this guide and youtube link but I’m not sure if it’s solving my problem…But I think for sure there is someone here that could help me answer that question :slightly_smiling_face:
https://gist.github.com/Karunamon/d3938368c548a61a5a41281bb89f0e49
https://www.youtube.com/watch?v=8VZOop8WARE
Thanks in advance!
I would first try to inject a hekate payload and check if autoRCM is active.
If so, You should disable it.
From the hekate bootloader I would check the fuses and try to launch ‘Stock(SysNand)’.
If the Switch boots up in original firmware I would recommend to stay offline with the Switch to avoid a possible ban.
Hi and thanks for the respond Calvin.
I followed the guide in the link from my first post and now are my switch back to stock 100% and it can be used as normal, signed in and downloaded things from the E store without any issues.
