Hey guys sorry to bother ! I’m currently trying to learn how to fix a Nintendo switch , and I kind of have issues knowing what’s in issue or not … Grinning face with sweat
To make it short, I bought a switch broken on ebay and I am trying to fix it the issues are this :
When I put the charger on the Nintendo switch, the name pop up and the then goes back to off and tells me that it’s not charge !
I’ve already try to hard reset et to charge the switch for like 2 hours like even a day and I manage to charge the battery but even with the green logo of battery the Nintendo switch doesn’t boot just the logo is coming put and disappearing after few seconds …
I’ve decided to crack open the switch and to check some problem and here what I saw : the M92T36 chip had some little Burning marks and some of the pins of the chips doesn’t have the right value in diode measurements !
By checking the voltage given by the usb C I might have done something that add an issue on something because after that when I plug only the charging cable on the switch when I press the power button it kind of makes a rumbling noises Grinning face with sweat
But still power on with the same issue.
My last test was to check some other shorts than the M92T36, BQ24193 and P13USB chips and I’ve found 3 !
Two are close to the MAX77 chip and one 33M79MZS
What should I do ? I don’t really care if it’s broken or unfixable because I bought it to learn but I’m kind of getting stuck Face with diagonal mouth
Thanks for your time and if you wanna do a discord call to explain it better this is fine to me !
(P.S I will leave some photos to show you the shorts !
