Multimeter Diode Testing HDMI
So I have an Xbox One X with a damaged HDMI port that I attempted to repair. I’m still not getting video after replacing the HDMI port *which had pre-existing broken pads I hopefully repaired.
Before going back in, I’d like to try and confirm if the issue is my repair or something else.
I found this video which has some good info on HDMI testing + some values for the port
youtube video ID 4VSkSGz6lPM
.688 G .688 .689 G. .688 .632 G .636 G
.633 G .634 .593 .557 .608 .624 G .595 .645
I’m getting
OL. OL. OL. OL G OL. OL. G. OL. G
OL. G. OL. OL. OL. OL. OL. G. OL. OL
I can’t get any non-ground readings? I tried another HDMI port, and I got the same thing. Do I have a bad multi meter? AstroAI WH5000A
Not sure what I would be doing wrong, but I’m also a noob lol? Thanks for any insights!
Did you chose the correct mode?
→ Selector to Ohms/Continuity/Diode → 2x ‘Select’ for choosing Diode Mode?
than red probe on GND and black probe to the pads?
Red on ground!!! I was pretty sure the black probe went to ground, but I see now that’s not the case.
Thanks so much :smile:
