I own a Gigabyte G5 KD-52US123SO. I bought it from NewEgg. The only thing I did was put more RAM into the laptop and added some NVMEs within the laptop. I transported it in a laptop bag, at destination, I set it up and used it for about a week without any problems. After a week, I put it in the laptop bag and drove back home. It was it the laptop bag in the back seat of my car for about five hours. When I set it up at home and pressed the power button. When I pressed the power button the laptop did not make any sound(s), nor did anything come up on the screen. It was dead silence, no reaction therefore I have no idea what could be the problem.
- Take NVME out, make sure connector clean and reinstall.
- Take out all memory modules out and then only install one.
- Start computer. If turns on then power off and add the other memory module.
- Start computer again. If everything starts then its ok.
- If not take 1st memory module out, move the 2nd memory to 1st spot.
- Start computer. If dosen’t start memory module is bad. If it dose start, second memory slot can be bad.
Apologies for the late response. I took everything off that I could; I avoided removable parts that would block operation.Then I began to add one item at a time with a power on/windows login test to verify if the part was good/bad. Turns out that it was an NVME. My thoughts were CPU or RAM, yet that proved to be false. Thank you for your response.
