Need component value near bios on PS4 pro NVB-004 board
Hi everyone, I bought this board to practice on, the owner claimed that it worked before but while trying to dump the bios he knocked some components with the soldering iron.
There were 3 missing resistors and one was missing a pad.
Unfortunately the boards that I have have only one 4.7k resistor on pin one, so I don’t know if there are supposed to be two resistors or a resistor and a cap.
Right now the board does not power on at all, it has 3.3v on the power button but when I press it the 12v does not enable. Which, as far as I know it is a southbridge issue.
Thanks.
I would check if the voltages are reaching the NOR ic. If not check the lines and the resistors on those lines.
Thanks for the help.
Unfortunately, I already did that, I get 3.3v on some and slightly less 3.298v on others.
As for the break in the lines, did that too, that’s how I found the resistor with the missing pad and how I found myself with two 4.7k resistors on pin one.
One was missing, the other read around 50k, looked on the boards I had and there was only one 4.7k resistor there. Didn’t turn on, checked for continuity on traces and that 50k resistor gave problems.
Removed it and noticed the missing pad, but after trying for a while it gave a 4.7k reading.
I would desolder the NOR ic again and check if the lines from the via side of the resistors are reaching the pads of the NOR ic.
I don’t think that’s the problem, the voltages were read directly on the pads on the sides of the NOR.
Plus, I soldered the resistors without the air station on purpose to not stress it, and I don’t think the seller used an air station either, he soldered the wires directly on the resistors.
To be honest, I think that he lied about it working before the NOR dump, the only reason to do this is to enable UART. But since I don’t know what components are near pin 1 I can’t be sure.
What is the ohms reading at pin 1?
At the moment I have only one 4.7k resistor installed so the components are the same as the other boards that I have.
Resistance to ground at pin 1 is 20k, diode mode (red probe on ground) is 0.528v
The resistance to ground on my (also only one 4.7k resistor version) board is 8.5k at pin 1.
Did you bridge the second place for the other resistor?
The variance in resistance is probably because of different revisions, the ps4 fat SAC-001 board (also one 4.7k resistor on pin 1 ) that I have has roughly the same 20k resistance, the only difference was in diode mode, 0.528v vs 0.582v
Yep, I had to put a jumper wire, otherwise it would not complete the circuit.
Can we just us jumper wires and bypass the resistors?
i got the same issue after reading the nor my ps4 did not want to turn on anymore
