Thanks Calvin for getting support in the diagnostic which helps a lot - much appreciate your work.
Before taking off the fuse (which honestly I have not understood what can I see once fuse is off) - I inspected USB-C connector a little bit depeer. Inside I could not see any problems, but checking the soldering of the PINs I have seen that 3 of them are not soldered on correctly. So I guess someone tried to replace the USC port before.
Once soldered them on correctly powering up was working - but unfortunatly switch is still not fully working. Backlight, Touch is working but nothing on the LCD screen. It looks like that one PIN of ther FPC Display Port connector is broken - so this probably needs the be replaced as well
Haven’t done this before - so hopefully I can manage this…
The fuse devide the power supply line in two parts: the usb c side and the m92t36 side. If the fuse is off, the shorting component should be only on one of the both sides. In your case the usb c side would be stayed shorted and the other side would be tested without shorts. → The short is at the usb c port.
From my point of view three loose pins can not short VBUS and GND. I would first check if all pins at the visible and hidden row are making good contact and do not short against each other.
