hello i got a nintendo switch that is not charging in his charging dock and with its charger but when put it with mobile phone charger its charging but at some point an ‘X’ appears after some times,when i unplug and replug the mobile phone charger it works but it takes a day to charge nearly full
The original Nintendo 15v charger needs to talk to the m92t36 ic inside the Switch, before switching power on. A 5v charger, like your phone charger, works without talkback and is only slow charging.
I would check the pins inside the usb c port and at the m92t36 the cc pins for propper readings.
No, I don’t think so. The battery is managed by the bq ic and only handles the voltage which forwarded by m92t36. If 15v isn’t delivered from the charger mostly there is a problem with the cc lines or the m92t36 itself.
Did you check both orientations of the usb c plug?
I would check both cc lines for correct values. In the picture the values are in diode mode (with red probe on ground/black probe on the testpoint)
The reading in resistance mode should be around 5M ohms.
If the readings are both present, there should be a contact problem with the usb c port.
If one cc line has no value (oL or some odd reading) there maybe a problem with the soldering at the m92t36 or (if present on the board) with the double diode ic (the part right of the both testpoints).
Do you have a breakout board for usb c? It would be usefull to check if the lines are passing through the usb c port. Maybe the port is not full soldered or something inside the usb port prevent good contact.
The reading depends on the multimeter you use. Other multimeter, other readings.
In the range +/- 10 it seems to be ok.
I would check the usb c port for loose pins and contacts.
One cc contact is missing, otherwise the Switch wound charge both ways around.
The missing 0.789 and the low 0.574 are the D+/D- for the usb communication. If those test points doesn’t have good readings, the Switch will not work in the dock.
