Hello everyone,
I bought a Nintendo Switch (HAC-CPU-21) that was unable to boot. I discovered a short circuit on the VSYS line and identified the culprit as the integrated LCD driver chip. After replacing the chip, the short disappeared.
I attempted to start the device using a bench power supply, but it still wouldn’t boot. The power supply read 0.25A-0.3A and didn’t go beyond that. So, I began checking all the power rails near the MAX77620 chip. The voltages for the first and second boot are present, but the voltage for the VDD_1v05a power rail is at 0V.
I checked in diode mode and everything appeared normal. I also replaced the MAX77620 chip, but the voltage is still missing on that line when I start the console from the bench power supply.
I even tried reworking it, but the voltage is still missing.
Actually there is no short on the board. I also removed the usb-c port, and now it is removed.
Any ideas?
