Nintendo Switch no screen docked
Hello,
I have a Nintendo Switch model HAC-CPU-10 which refuses to display an image on the television.
I changed the P13USB, the charging connector, the M92T with no more results.
The screen goes black when the console is in the dock but nothing is displayed.
I found a diode next to the M92T which had burned down, I changed it. I also changed a capacitor under the P13 which had disappeared.
I tested the filters, none are damaged.
I’m not sure where to look for more …
I also found a capacitor, at least I think it was a capacitor, which is ripped off next to the ALC component but I don’t know the value. I didn’t replace it suddenly but I don’t think it has anything to do with it, do I?
Thanks to you for your future help;)
Hello,
If a moderator see this message, you can delete the topic. I find the solution. Thank you.
But what was the solution? We need to know now! :laughing:
Oh ok !
As nobody ever answered, I thought nobody interested;)
It was a capacitor to the left of the P13USB. There are two 100K resistors, one of them gave 47K. I changed the capacitor that followed and the resistor returned to its value.
The image on the dock came back afterwards.
Oh, interesting. I haven’t heard of that as an issue before, nice find!
Can you please show à picture ?
Congrats for the hard work!
Hello,
Thank you.
The resistor with red square was the faulty my case.
https://ibb.co/NZYyz9F
I hope that could help you.
Hi there Tiripstruk. So if none of the things are working out for your switch while it is docked i would like to suggest moving the board that is in the dock itself. i have fixed many of the first gen docks this way. You will move the board closer to the cord ports for power and hdmi. I know it sounds weird but i know that is is a simple fix. it is mainly do the the power cord not fulling engaging into the dock itself. Hope you have a good day.
Hi man
Can you please tell me where I can find this PCB schematic layout diagram you showed in the image you shared
