good evening.
i have a question regarding an issue i have with my nintendo switch.
so i modded my nintendo switch by replacing the housing to an all metal one, including the controllers. it worked perfectly fine before i started messing with it.
(well aware of the risks i take when messing with stuff but i just like modding stuff)
so i put it all together (after being apart for over 6 months), tested it before closing it up for good. found out the backlight was on but no image was showing. so i thought i had broken the screen or the flat cable since i had a bit of a fight getting it seated. ordered a new one and installed it but still have the same issue. i then also noticed it doesn’t boot without a charger connected i can hear sounds when i touch the screen or press a button on the controller.
when i put it in the dock it works just fine and shows an image on the TV (does show the battery and says it was at 97%), but on the switch itself i could only see the backlight come on for a moment.
i did a few basic checks:
charged the battery for over an hour to be sure. didn’t help.
checked battery voltage: 4.16V, so that is acceptable with no load applied.
i found a treath on this forum to check a few voltage related to the screen ( cant find it anymore) one was 5V and the other was -5V just as was mentioned. also the enable signal of 1.8V was present.
anyone has an idea what it can be or what i can check?
thanks in advance
