Hi there, I got a PS4 SLIM SAD-001 that does one beep blue light shows 1sec and turns off, eject button can 3beeps all the time though. Weird thing is it will turn on just fine if I keep trying pressing power button and wait for another cycle, about 5~10 times, it will just boots up fine.
I tried known PSU, no difference, and did check NOR dump with validator, and even no short on board( since it would still boots up).
Standby voltage checked ok, current draws about 0mA->125mA->24mA, it seems good to me.
Next, I would try replacing the CXD90036G SB and see if anything change.
Any thoughts are welcomed!
I think 1C5210 is part of the data for 1C5200.
80000009 and 80810011 are the error codes.
Till now I haven’t found a PS4 UART error list beside Update and Network errors. No hardware related errors.
I found the culprit in my case: a resistor with far off value. ToltecMerc had an similar case. After replaceing the resistor, the PS4 is running without issues.
