hi.
have a good day everyone
problem with the motherboard when I start it, the first start time beeps and after 2 seconds it turns off. When I examined the motherboard, the F7003 fuse was broken. i changed i didn’t get result
The values of all coils are normal. The CPU circuit is 1-2 ohm but not a short circuit. Because they have the same low value on the zen cpu value graphics cards
I measured the voltages of the active coils at the first start time with an oscilloscope. everything is smooth. all voltages in the coils are activated for 2 seconds. The current drawn is up to 7 amps.
Bios Eeprom Data Read the first start time
my first question. Is this coil ohms normal?
Coil with two opposite GPU
my other question. What is the name of this ic?
2419
G0NBA
marking code
Let me mention that, the same was not used in this ic ps5 motherboards.
700BNL (marking code) on my motherboard used
