PS5 displays logo then shot down!
Hello.
I have a PS5 that has the following problem. It starts but when it reaches the logo and should enter the dashboard, it suddenly stops. If I enter safe mode, I have no problem, I can navigate through the settings without stopping. I tried reinstalling fw and recovery, nothing worked. How to get to the logo and enter the menu suddenly stops. I changed the HDMI encoder IC but it does the same thing. I did not detect any short around the encoder. I changed the power supply and it does the same.
Does anyone know what it could be? Thank you in advance!
UART cod error:
$ [MANU] [ACINDET] AC IN DETECT Low:A7
OK 00000000:3A
$$ [MANU] UART CMD READY:36
errlog 0B
OK 00000000 80802220 02A4B0BE FFFF0005 00000100 2013 0036 234D 1708:3A
Error code: 80802220
Description: Known Unknown 80802220 (Power or Short) - Report Findings
are there more error logs? (errlog 1, errlog2,…)
Only the one mentioned above. Else nothing.
Does the ram ics differ in temperatur?
As long as it starts to work until it stops, I have not noticed that any ram ics gets excessively hot. I don’t have a thermal camera. I just put isopropyl alcohol on each one.
If you look at the power consumption at pluggin the power, I guess it is normal. Within 5 sec up to aprox 310 mA back to aprox 8 mA?
