Good Day Everyone,
I’m quite in a huge pickle.
I did some troubleshooting on an uncharging mobo, to my discovery that one of the pins of the usb type c port was missing. So I decided to replace it.
Upon finally removing a faulty type c port, I noticed that two pads to the far right (of the pic) is missing! The bare copper that was there to provide conductivity for type c connection is gone!
Not sure when this happened, but my guess was when I was removing the port.
Is there anyway to order some copper strips to that size to recreate conductivity for the type c pads? I marked the issue with red arrows and circles the pads in blue.
Can you provide any solutions or is now the whole board toast? The board works with a full battery, but I had an error code of 2134-0501 pop up on boot which is prob that m29chip thing.
But if I can’t fix the type c problem, it almost seems there’s no point to switch a potential m29chip fault.
Are you able to assist?
Thanks
