SD card reader not getting 3.3V
Hi all!
Long time lurker, first time poster here.
I have have issue where sd card reader is not getting 3.3V. I checked continuity from the board to the sd card reader pins and they are all good. If I remove the card reader there is also the detection voltage at 1.8V.
I also have diode readings close to the values I have found from the forum.
[Adding pic when I can]
I’m getting 1.8V from the yellow point and there is 3.3V from the red points. The green point goes to other side above to the sd card reader. Picture is just for the reference. My board is HAD-CPU-10. [Adding pic when I can]
What should I check to get the sd card reader to work? Everything else seems to be working, charging, docking etc.
