Strange charging switch
Hi, i repaired a Nintendo Switch with (HAD-CPU-01), i replaced the USB connector and the M92 chip.
Now I reassembled the console and it charges, but if the console is turn off and i plug in the cable, the console charge (charging screeen), it turns on (the reader of the charger turn off and on again), but after that there is no way to charge the console. It stays a 5 V with 0 amp and the only way to charge it again is turn off, turn on with out the charger then plug the supply and it works correctly, what could be?
Somebody had see this problem? thank you
Other info, if it turns on with the charger (before was off) it ddin’t charge and if i press the power button, the console died, there is no way to turn on again.
I need to keep press the power button for 10 seconds, after that i press again the power button and it turns on correctly.
The M92 i replaced was defective?
