Switch Oled - new component next to BQ24193 - barrier diode?
Hi all, can anyone confirm this component is a barrier diode? (perhaps a CUS10S30)
{pics to follow in my reply}
It wasn’t on the non-Oled Switch and I think the one I have on my Oled Switch is faulty… I’m considering not replacing it if non-critical.
Open to suggestions
Thanks
What am I doing wrong? It says “An error occurred: Sorry, you can’t embed media items in a post.” when I try to add a pic
It’s been there since NS lite if you’re talking about that little guy.
If your Vsys(2R2 Inductor) diode/resistance reading is normal, you can ignore it, and I believe v2 mariko board doesnt have it by default.
Thanks jkyoho
The Switch wasn’t turning on and it wasn’t taking a charge either, but there was no short.
My voltage drop on Vsys was 0.08 and after removing nearly all the IC’s looking the culprit, I think it was actually this guy all along. I say that because the voltage drop is now in the 0.4 region on Vsys.
Vsys voltage drop is around 0.10x V~0.11x V from V2,lite board AFAIR. I don’t think 0.08 reading is too far off.
Oh and I meant v2 some early board does not have this diode but most do, I just saw the v2 board on my bench has it. LOL
I recalled my memory removing the diode does not effect the Vsys voltage drop reading, memory maybe wrong…
Well it was a red herring…
The voltage drop did increase, but it did not solve my problem.
Where is the 2R2 inductor on the board please
It is the big grey coil next to your missing diode.
thank you so much. I appreciate it
