I’ve got a switch OLED model that is in working condition other than it won’t display anything on the OLED screen.
It charges, touch screen works, it’ll display on a tv if it’s docked, etc.
I tried a factory reset and re-seated the display connector and it’s still doesn’t work. There doesn’t appear to be any visible damage on the board or connector, the ribbon cable for the screen looks good, and the capacitors near the screen connector seem to be fine.
I’ve done some other detective work with other repair groups online and I think it might be narrowed down to a DOS04 chip on the back side of the board underneath where the screen connector is. I searched for this chip online but can’t find an exact model match. I found similar ones on aliepxress and one of the listings mentions “light control” so I’m thinking I’m on the right track, but I have no idea.
So I’m curious if anyone else has had this issue? Any other ideas to test? I’m I out of luck for finding this part?
I have the same issue. I tried replacing both the screen and the FPC connector, but it didn’t solve the issue. Has anyone managed to find a solution yet?
Unfortunately, I don’t. I looked everywhere in my files and can’t find where I ordered it. BUT if you look up DOS04 chip on google you might be able to find something?
P
LABEL PF3I goes for TPS65633BK, and DOS04 for S2DOS04. they’re both custom chip so data sheet not available for public.
OLED has no different circuit design for oled drive and i have seem both chip been used on oled model.
You could only find typical phone screen led drive circuits using dos04 chip as reference
Hi guys
I have a same issue with a oled. Replaced the lcd chip, but same issue. Seems the issue comes from another part on the pcb. Is there any lcd fpc connector pinout available anywhere?
