Switch orange screen
Hi guys
I think the cause of the switch orange screen is the Bluetooth and Wi-Fi modules. Does anyone know how to fix it?
I solved that.
The repair that reworked the 4356 chip in a friend’s uploaded video
When I use it, the symptoms come back
If after reflow it does so, then you can try a chip reball which will be very difficult because the balls are very small in size, or you will replace it with a new one.
https://www.aliexpress.com/af/BCM4356XKUBG-.html?d=y&origin=n&SearchText=BCM4356XKUBG+&catId=0&initiative_id=SB_20200205004058
hi i wanted to know if you could help me with my switch it has the orange screen problem and the display wont show while in the dock
fxdx friends
I changed the bcm4356 module and it wasn’t solved.
Have you changed with a new one or one from a donor switch board? A new one will have to be programmed with the wifi code version for the Nintendo Switch and I really don’t know how to do it without special tools.
bcm4356 why not
Is the wifi firmware wrong?
So is there a way to get out of the orange screen is that there is no way other than sticking on the donor board?
On the donor board !
