Test the red wire voltage on the battery rail (with the battery in) when plugged in? Should be more then 3.7 volts. If it is, blame the battery. If its not, its not receiving enough power. I would like to see your solder joints on those chips you replaced? Please upload photos?
Yep. This is the “Dead Battery State” where boot will be halted until the battery reaches a certain threshold. The M92 handles this situation (it’s documented in the data sheet) and allows the power subsystem to re-establish itself without any intervention from the PMIC. This process takes time as even with the OEM charger, the process is trickle charge only (0.42A normally). Once the threshold is reached, the PMIC kicks into life and permits fast-charging to initiate.
