Hello, anybody ever have a switch that is slow to recognize when it’s connected to a charger? Once it does recognize it, charging is solid. I can jiggle it till the cows come home. It also doesn’t matter which way the plug is in. It just takes about 5-10 seconds until it sees it. Normally, I can plug a switch in and it gives me the charging symbol immediately. Is this normal behavior or definitely something off?
Clearly abnormal, try turn it off and clean/brush the port with Isopropyl alcohol and let it dry
check the resistors around BQ, i had a switch lite with similar issues and turns out 1-2 of the resistors had been damaged. Worth a shot at least
