Xbox Series X HDMI Issue: Unexpected Reading on Pin 14
Hello everyone,
I’m facing an issue with the HDMI port on my Xbox Series X and could use some guidance.
  1. Background: After a previous repair attempt elsewhere, the HDMI port was damaged, and 11 pads were compromised. I replaced the HDMI port and fixed the pads successfully.
  2. Testing: I used an HDMI breakout board post-repair. Everything checked out initially. But when I reassembled the Xbox, the HDMI failed to operate correctly.
  3. Pin 14 Anomaly: Upon re-testing with the breakout board, I noticed that Pin 14, which should read ‘OL’, was now showing a reading of .8xxx. Notably, this was the only pin with a changed reading.
  4. Diagnostics: I began a step-by-step disassembly, noting the readings after each component removal. The ‘OL’ reading on Pin 14 returned once I disconnected the ribbon that links the two main boards.
  5. Main Board Suspected: I tested with various southbridge boards, but the .8xxx reading persisted. This leads me to believe the issue might reside in the main board.
Has anyone come across this specific issue or have insights on HDMI-related problems of this nature? I’m trying to pinpoint the issue, and any help or advice would be greatly appreciated. Thanks in advance!
Please delete your old post.
Down at the three dots beside the Reply, it will show you at your posts a delete button.
(Tried to insert an image, would not let me)
Does not appear to be there. I can try to message a mod and have them remove it! Thanks for the heads up though.
This dots are not present in your view?
Tronicsfix
